Submission url compatibility error
3711
03-02-2020 08:40 AM
FranklinAlexander
I am getting the following error:
Survey123 error 400 "custom feature service submission url is not compatible..."
even though according to esri documentation my submission url is correct.:
How To: Create Survey123 for ArcGIS surveys that connect to non-federated ArcGIS Server services
The id in the submission url matches the id of the survey which I got from the survey url as instructed in the above doc.
Url to the survey
https://survey123.arcgis.com/share/+ surveyId
submission url format I am using:
ArcGIS Portal Directory + surveyID
Is there some other reason I could be getting this error?
Shwu-jingJeng
Hi Franklin,
The submission url you referred for portal should not end with surveyID, it should the the item ID you added from the feature service(step 1-4). Could you double check to see if you are using the correct item ID?
Shwu-jingJeng
Hi Franklin,
