Unable to add field (button disappeared) to Hosted Feature Layer
2284
02-27-2020 06:08 PM
JackSilburn
Hi
When I first published my dataset to ArcGIS Online, there is an option in the hamburger menu to 'Add Field'. However, now I notice it has disappeared:
There are only the three options in the screenshot.
This is how the item is described in the Overview section:
I have since joined the layer with another layer, which has created a view. I am guessing this is the problem.
This is supported by the add field documentation (at the bottom): Add or delete a field—ArcGIS Online Help | Documentation
Restrictions when adding or deleting fields
Consider the following when adding or deleting fields:
  • You cannot add fields to or delete fields from copies of hosted feature layers, hosted feature layers that have related tile layers, or views created from hosted feature layers.
I would prefer not to have to delete the layer and re-publish it, because that would mean rebuilding my Dashboards and Web Maps etc.
If there is a workaround that would be great.
Thank you
BenjaminSperry1
Hi Jack,
I may have made some progress although not fully yet.
I followed this article to update service definition.
I change "sourceSchemaChangesAllowed" to 'true'
Everything seems to work but when I refresh the page it is reset to false.
Let me know if it works for you. or anyone else if you have found a solution.
Thanks.
JayJohnsonWashoeCounty
Benjamin,
YES, this is a major pain when using joins to create views on hosted layers in AGOL.
There is no work-around - you will have to bite the bullet and recreate part of your content.  The GOOD news is that the webmaps are easy - you can use the  ArcGIS Online Assistant  to simply re-point the relevant layer in your webmap to the new URL of your re-created view.  The BAD news is, yes, you have to change the data source in any widgets in the dashboard, which loses some of the configuration for that widget.  I take plenty of screen shots of my widget configuration screens before I make a change like this.
Vote for this idea:  https://community.esri.com/ideas/18414
Jay
Jay
Washoe County GIS
BenjaminSperry1
Hi Jay,
Thank you for the insight; sad to hear but glad to avoid the pain thinking there is a better way while I tediously duplicate work. Also, thank you for the link to ArcGIS Online assistant I wasn't aware of this tool and it will be very helpful in overcoming this challenge. I will up vote the idea.
Ben
