Hi
I have a user with ArcGIS Desktop 10.7 that will not open Arcgis Administratot
When you install Arcgis it will open the license manager after install and then you can input the license server details
however once you have completed this, it will not open again so you cannot borrow licenses
when i check Services.msc , their is no flexnet service listed
I installed the ArcGIS License manager onto it, and it worked, but as this was for a server i removed it.
Can someone advice what can be done? can i install Flexnet service from someone
thanks
Aidan McGee
Aidan,
The Flexnet Licensing Service should be installed with ArcGIS Administrator. If it's missing, you can install the service by installing the ArcGIS License Manager. It is the same service installed with the ArcGIS Desktop. The other issue is that you were not able to start the ArcGIS Administrator. This should be able to start regardless the Flexnet Licensing Service was installed or not.
In your situation, I would just reinstall ArcGIS Desktop and verify the Flexnet License Service was running once completed. If not, just install the ArcGIS License Manager. You can then remove the license manager if you want to. The Flexnet Licensing Service should only uninstall you you remove the last ArcGIS application.
