Python Create and Cleanup Topology
4125
03-23-2011 01:14 PM
MichaelGartrell
I need some help getting started.  What I want to script is
  1. define some simple topology rules for a single dataset (must not have gaps, must not overlap self),
  2. validate the topology,
  3. step through each error and apply an automatic fix depending on the type of error (as from the context menu when viewing topo errors in ArcMap)
Can this be done?  Can someone point me to some examples, documentation, etc?  I've looked and all I can find is a posting about deleting existing topology (like http://forums.arcgis.com/threads/21947-Can-a-topology-rule-in-a-personal-geodatabase-be-deleted-usin...).
Thanks.
Michael.
BillBass
Yes, you can. Here are some sample scripts we use in a Python batch program. However, I have yet to find a method to extract the value that are displayed in the Generate Summary after the topology has been validated. I have seem a couple of other posts on the same topic, but no responses.
import arcpy
Scratch_Workspace = "G:\\CE\\Forecast\\Parcels_2008_2010\\Parcels_Scratch.gdb"
arcpy.env.workspace= Scratch_Workspace
arcpy.env.overwriteOutput= "True"
#Creates Feature Dataset and loads dataset into feature dataset
arcpy.CreateFeatureDataset_management(Scratch_Workspace,"Parcels_Topology","Parcels_Overlay_WD_Dissolved")
arcpy.Select_analysis("Parcels_Overlay_WD_Dissolved","Parcels_Topology\\Parcels_Dissolved","")
#Creates topology and adds loaded dataset to topology and assigns rule
arcpy.CreateTopology_management("Parcels_Topology","Parcels_Dissolved_Top","")
arcpy.AddFeatureClassToTopology_management("Parcels_Topology\\Parcels_Dissolved_Top","Parcels_Topology\\Parcels_Dissolved","")
arcpy.AddRuleToTopology_management("Parcels_Topology\\Parcels_Dissolved_Top","Must Not Overlap (Area)","Parcels_Topology\\Parcels_Dissolved","","","")
#Validates topology
arcpy.ValidateTopology_management("Parcels_Topology\\Parcels_Dissolved_Top","Full_Extent")
BillBass
Yes, you can, to a point. Here are some sample scripts we use in a Python batch program. However, I have yet to find a method to extract the value that are displayed in the Generate Summary after the topology has been validated, or repair them in some automated fashion.
import arcpy
#Validates topology
JesseSheridan
Anybody have any luck Generating Summary for Topology Errors in an automated way?
