ArcGIS Pro 2.5 New Env but...
6362
13
02-11-2020 09:50 AM
JoeBorgione
Just installed pro 2.5 and cloned  the default environment.  When I click on the start menu navigate to Anaconda3(64-bit), I find Jupyter Notebook, Reset Spyder Settings and Spyder.  However, they all point to my old (2.4.3) environment.
My spyder desktop shortcut  points to the old env, but I would expect that.  After changing the paths to the new env, it works, albeit with the older 3.3.6 version; again not unexpected.
Where did the Anaconda3(64-bit) folder come from in my start menu, and how do I convince it to choose the right path?
Dan Patterson
DanPatterson_Retired
Joe ‌ its time for you to go home and rest up....  ... or go have a jog without beer ....
--dry-run
just "pretends" to do the install
you check it out, then
... remove --dry-run from the line
If you are doing a clean install from the *.msi, you need to rename any esri folders in your user profile's App folder.  I usually do the same with any spyder, anaconda etc folders so if you want to copy *.ini files over you can.
JoeBorgione
That's exactly what I'm going to do: I have uninstalled pro and I'm just waiting for our sys admin to download the msi.  thanks.
Hopefully you have full admin rights to your local machine to finish the cleanup in your user folder
JoeBorgione
Dan Patterson    Yes- I have admin for my machine and I'm done with the install.  I love this part in the online help (Python Package Manager—ArcPy Get Started | Documentation ) :
By default, the latest version of each package is shown, but you can also access earlier versions by clicking the version number in the Version column. To install a Python package, click the package name in the Name column, change the version if necessary, and click the Install button.
Which is why spyder 3.3.6 ships with ArcGIS Pro 2.5  Currently in my new Clone25 I have spyder 3.3.6 and spyder-kernels 0.5.2.  In my 2.4.3 clone I had 4.0.1 and 1.8.1 respectively.  Since neither of those are available in the ArcGIS Pro 2.5 updates, I guess I need to get them. In you recent post, /blogs/dan_patterson/2020/02/09/clone-arcgis-pro-25 , I don't see any mention of updating packages.
According to Releases · spyder-ide/spyder · GitHub :
If you are new to Python or the Scientific Python ecosystem, we strongly recommend you to install and use Anaconda. It comes with Spyder and all its dependencies, along with the most important Python
I don't remember updating my spyder in 2.4.3 being so much trouble.  What are your recommended steps to ensure I have the latest-greatest Spyder and other dependencies?  I think Jupyter is one of them....
JoeBorgione
Here is my current conda info:
(arcgispro-py3-clone25) C:\EnvClones\arcgispro-py3-clone25>conda info
Current conda install:
               platform : win-64
          conda version : 4.3.27
       conda is private : False
      conda-env version : 4.3.27
    conda-build version : 3.18.9
         python version : 3.6.8.final.0
       requests version : 2.22.0
       root environment : C:\Program Files\ArcGIS\Pro\bin\Python  (read only)
    default environment : C:\EnvClones\arcgispro-py3-clone25
       envs directories : C:\Users\JBorgione\AppData\Local\ESRI\conda\envs
                          C:\Program Files\ArcGIS\Pro\bin\Python\envs
                          C:\Users\JBorgione\.conda\envs
          package cache : C:\Users\JBorgione\AppData\Local\ESRI\conda\pkgs
                          C:\Program Files\ArcGIS\Pro\bin\Python\pkgs
           channel URLs : https://conda.anaconda.org/esri/win-64
                          https://conda.anaconda.org/esri/noarch
                          https://repo.anaconda.com/pkgs/main/win-64
                          https://repo.anaconda.com/pkgs/main/noarch
                          https://repo.anaconda.com/pkgs/free/win-64
                          https://repo.anaconda.com/pkgs/free/noarch
                          https://repo.anaconda.com/pkgs/r/win-64
                          https://repo.anaconda.com/pkgs/r/noarch
                          https://repo.anaconda.com/pkgs/msys2/win-64
                          https://repo.anaconda.com/pkgs/msys2/noarch
            config file : C:\Program Files\ArcGIS\Pro\bin\Python\.condarc
             netrc file : None
           offline mode : False
             user-agent : conda/4.3.27 requests/2.22.0 CPython/3.6.8 Windows/10 Windows/10.0.18362
          administrator : False
conda install blah_blah --no-pin --dry-run
make notes to you can use
conda install --revision X
to roll back any serious issues
has the visual for updating Spyder
instead of "install", use "update in its place
JoeBorgione
Dan Patterson- I did see your update instructions (remember my old eyes...) at any rate having run the updates as shown in your post I'm not seeing spyder being updated:
Echoed back from the conda update command when I run it as my normal login:
(arcgispro-py3-clone25) C:\EnvClones\arcgispro-py3-clone25>conda update spyder --no-pin --dry-run
Fetching package metadata .............
Solving package specifications: .
Package plan for installation in environment C:\EnvClones\arcgispro-py3-clone25:
The following NEW packages will be INSTALLED:
    argh:                   0.26.2-py36_0
    autopep8:               1.4.4-py_0
    bcrypt:                 3.1.7-py36he774522_0
    diff-match-patch:       20181111-py_0
    flake8:                 3.7.9-py36_0
    intervaltree:           3.0.2-py_0
    libspatialindex:        1.9.3-h33f27b4_0
    paramiko:               2.6.0-py36_0
    pathtools:              0.1.2-py_1
    pexpect:                4.8.0-py36_0
    pydocstyle:             4.0.1-py_0
    pynacl:                 1.3.0-py36h62dcd97_0
    python-jsonrpc-server:  0.3.4-py_0
    python-language-server: 0.31.7-py36_0
    pywin32:                227-py36he774522_1
    pyyaml:                 3.12-py36h1d1928f_1
    qdarkstyle:             2.8-py_0
    rtree:                  0.9.3-py36h21ff451_0
    sortedcontainers:       2.1.0-py36_0
    ujson:                  1.35-py36hfa6e2cd_0
    watchdog:               0.10.2-py36_0
    yaml:                   0.1.6-vc14_0         esri [vc14]
    yapf:                   0.28.0-py_0
The following packages will be UPDATED:
    jupyter_client:         5.3.1-py36_0         esri --> 5.3.4-py36_0
    jupyter_core:           4.5.0-py36_0         esri --> 4.6.1-py36_0
    spyder:                 3.3.6-py36_0              --> 4.0.1-py36_0
    spyder-kernels:         0.5.2-py36_0              --> 1.8.1-py36_0
The following packages will be DOWNGRADED:
    jedi:                   0.15.1-py36_0        esri --> 0.14.1-py36_0
It appears to have updated, but:
 C:\EnvClones\arcgispro-py3-clone25>conda list spyder
# packages in environment at C:\EnvClones\arcgispro-py3-clone25:
spyder                    3.3.6                    py36_0
spyder-kernels            0.5.2                    py36_0
sigh....
--dry-run
JoeBorgione
I thought dry run was a reference to gin; I used to jog, but the ice kept falling from my glass....
(arcgispro-py3-clone25) C:\EnvClones\arcgispro-py3-clone25>conda list spyder
spyder                    4.0.1                    py36_0
spyder-kernels            1.8.1                    py36_0
finally..... thanks!
