I have installed the Cyclomedia Street Smart add-in for ArcGIS Pro 2.5 but cannot login. Is this supposed to be my Esri login?
Hi, i have ArcGIS Pro 2.9.3 and i had the same problem.
It was a problem with the proxy.Now it's ok
In Street Smart for ArcGIS Pro, choose Configuration then Proxy server and check Use a server proxy.
Fill the fields : adress and port with your proxy adress and its port.
May be it will work. Have a good day.Regards
Claude
