UNA Error Failed to execute Parameters are not valid
Hi, I am using ArcMap 10.5 for Desktop. I am trying to compute the reach centrality, but when I run the UNA tool I get these errors: Error Failed to execute Parameters are not validERROR 000996: Cell size must be greater than zero. Failed to execute (PointToRaster) I'm not sure what's going on, since I used the UNA Toolbox…
Best Parcel Data Subscription
Hi there!! I was wondering what service people use for a parcel spatial data subscription? My org currently uses parlay from report all usa- but I figure there might be something more compatible with ArcGIS. I did see ParcelAtlas but I'd be interested to learn how that one works too. Thanks!
How to apply attributes to digitized buildings
To create rectangular buildings I use the "Drawing" toolbar which also allows to create L-/H-shaped buildings etc. However I can only define the colours of outline/area and not assign any attributes like 'age of house', 'social status of owner' etc. When I create a polygon feature I can assign all the attributes that I…
Can outside users add data to story maps in a website-like platform?
I'm wanting to use a story map as a website for public outreach and engagement with the design and implementation of a small city's general plan. Ideally, the platform would have both static, informational media content as well as a base map, or a series of base maps, that are editable by the general public. The main idea…
I am trying to name private streets on private apartment complexes that do not have names. accomplishing that we will help the emergency teams and the community. when you name the streets by the building next to it, you have to have a marker for location
I am trying to name private streets on private apartment complexes that do not have names. Accomplishing that we will help the emergency teams and the community. when you name the streets by the building next to it, you have to have a marker for the location then if they change management the building's name may change,…
How can I make imagery that I've downloaded from an online mapping service available for use offline?
I am using ArcMap version 10.6 and I have downloaded mosaic imagery from TNRIS. The imagery is for use on a field laptop and there will be no internet connectivity. The imagery works fine when connected to internet. Is there a workaround to get the imagery to appear when not connected to internet?
Merge lines at endpoints, yet still be continuous
I've created a sidewalks/walkways network but I'm having issues intersecting lines. What I'm trying to achieve is for the lines to split at intersections, but yet be continuous; as in, I do not want one line over the other, I would like for them to show as connected and continuing. I've provided an image if it helps.
Walkability Analysis Question
New to the community, so apologies in advance if I have left something out here. I'm thinking of an analysis in my head, wondering if it has been done somewhere else. Basically, within a designated subarea in a city (think 1/2 mile area surrounding a transit station) using the network analyst tool to count the number of…
Converting a point shp to a line shp while keeping the attributes
Hey, I have a point shapefile with points at a 1km distance from each other along the English southern coastline. I want to convert this shapefile into a line shapefile, and to keep the attributes from the original shp. Is this possible? Please find attached, there are some islands as well, that should be separate…
How do I make the time slider work with col
I have a table of average sale prices by school district monthly from jan2010-jan2020. I need to time slide or animate change via chloropleth. Time slider won't allow it. If I transpose the table from horizontal to vertical I can't join the data. Ideas? Current table (Joined but will not time slide) : District jan2010…
street smart login failed
I have installed the Cyclomedia Street Smart add-in for ArcGIS Pro 2.5 but cannot login. Is this supposed to be my Esri login?
How to merge polygons without changing size(ha) calculation/ calculate density per urban green space/ etc
Hi, I'm doing a spatial analysis of areas that need more green space in order to meet certain criteria: - at least 1 x 2ha in size, less than 300m from home - at least 1 x 20ha site within 20km from home - 1 x 100ha site within 5km from home - 1 x 500ha site within 10km from home - minimum 1 local nature reserve per…
Move verticies at intersection of lines in ArcPro
Hello! I am working with a county-wide road centerlines dataset and we need to be able to: -Edit existing road centerline features while preserving attributes -Create a dataset free from dangles (where appropriate). So my question is: In places where multiple roads come together we need to be able to modify geometry…
How to EASILY create a parcel/lot split from survey data using Arcgis Pro (not using parcel fabric)
Hi there! I am new to Arcgis and am using Arcgis Pro to create a new parcel or lot split. I would greatly appreciate a easy solutioin to SIMPLY create a new parcel (to scale) using the following suvey data. Everything I read online about parcels invloves the parcel fabric....I work for a consultant not a goverment agency…
Raster calculate based on altitudinal values of a river section - ArcMap
Hello, I want to know how I can model the elevation of a 12 meter rise in water levels from a river on ArcMap. The river is not situated at 0 level altitude in the DEM and hence i cannot just do a simple raster calculation which takes all areas belore 12 meters. I want to figure out the areas in which there can be a 12…
I am trying to assign values to a new field (1 or 0), based on whether there are particular attributes present in another field, in the same table.
I have an attribute table for a shape file, that has the attributes for a number of polygons. I have created a new field, that I need to have values of 1 or 0, based on whether there are attributes present in a different field. This is all being conducted within the same attribute table.
Mile marker symbology in ArcGIS PRO
I have been having a lot of difficulty generating mile markers for a route on ArcGIS Pro. After much trial and error I was able to create points along the desired line at the desired intervals, however, I wanted the symbology to reflect the mile number. I used various labeling techniques and ended up getting close to what…
How can I select street segments (polylines) based on intersections with others? Then, how would I add a value to its field from an excel table?
I have a shapefile of city streets polylines and an excel sheet with similar data. I need to select a street segment based on the two segments it intersects. Then I add the value from the "ID" field that corresponds with the excel sheet. Right now, I have to do this manually for thousands of segments by looking at the map…
I am trying to calculate CVI(coastal vulnerability index)using 7 parameters. shoreline change rate,geomorphology,mean sea level rise, tidal range, wave height,coastal slope and regional elevation.when i am putting the CVI formula in raster calculator it i
I am trying to calculate CVI(coastal vulnerability index)using 7 parameters. shoreline change rate,geomorphology,mean sea level rise, tidal range, wave height,coastal slope and regional elevation.when i am putting the CVI formula in raster calculator it is returning me values in highest=1#INF and Low : -1.79769e+308.…
Check out this Article on how google is fighting climate change
Google’s Tool to Help Cities Fight Climate Change - The Atlantic
Empty out_table from aggregate polygons tool
Hello, I am using aggregate polygons tool to combine features - in my case building lots whose boundaries are within 5 meters of each other. I also ask the tool to only keep those features whose combined area meet a minimum threshold of 1500 square meters. I opt in for an output table to be created as well, using the…
How do you estimate population served by a road?
I have layer of road and building footprint.
Smooth edges
Hi, My name is Cindy. Currently, I am doing a job about coastal management. I am pretty new using Arcgis and I use mosaic to new raster to merge 2 different raster of the same place. Before that I use Resample to obtain the same cell size, but there is a problem when I am merging them this appears, there is some way to…
How to create a proportional buffer based on population of a different shape's field? (Equity Mapping)
I am trying to create an "equity map" that shows proximity of different types of parks and facilities to a determined population of a town. (ex. neighborhood parks to nearest 500 people, and create a buffer or ring of sorts to those 500 people surrounding the parks) I have a census file of all blocks within the town and…
Issues importing room tags and door swings into ArcMap using the FME converter for Revit files.
Below as a screenshot of the Revit project (what i am trying to export) followed by what I am able to convert and export into ArcMap. Missing room tags and door swings.
