Sketch Polyline "undo vertices" removing last 2 vertices at ArcGIS JavaScript API 4.14
4619
02-10-2020 11:37 AM
RyanSutcliffe
I just noticed after recently updating our ArcGIS JavaScript API to 4.14 that hitting "z" to undo a vertex on a polyline in edit or sketch mode is now removing the last **2** vertices placed.
Took a look and the behavior seems also to occur in the ESRI sample online. Just wanted to confirm this is a **bug** and not some intended behaviour. Also if anyone has found a workaround or hack fix would love to hear. There's some improvements at 4.14 that we'd otherwise really like to take advantage of.
AnneFitz
Hi Ryan,
Thanks for reporting this. I was able to reproduce the issue in 4.14. We will investigate the cause of this bug and fix it.
Thanks again,
Anne
AnneFitz
Hi Ryan - just wanted to let you know that this will be fixed when 4.15 is released! Thanks again for reporting.
