Multiple lists or "drop downs" for one field, possible?
1179
02-06-2020 12:27 PM
DillonKubiatowicz
I am creating a map to record data and locations of chemical spraying for noxious weeds throughout a county. Obviously the type and amount of chemical needs to be recorded each day.  I am trying to figure out the simplest way to record this as there is a possibility of using multiple chemicals in a tank.  I understand how to create lists for a field, but I am wondering if its possible to create more than one list or have multiple choices for a specific field? Example: I am using Round-Up (out of 4 choices of chemicals) and put 10 oz. in a specific tank. My field could be labeled "Chemicals" and the list associated with it could be the list of chemicals, but how could I enter in the amount as well?  Sorry for any confusion...thanks for the help.
Dillon
by Anonymous User
Not applicable
Hi Dillon Kubiatowicz‌,
Some ideas off the top of my head are to create a longer pick-list using coded value domains that have each value already created. e.g. Round-up 4 oz, Round-up 6oz, Round-up 8oz., etc. Otherwise you would need to use two fields to store the data. What field app are you planning to use for collecting data? This would also influence the data design; you may be interested in Cascading and external selects—Survey123 for ArcGIS | Documentation
Hope this helps,
-Peter
