plot a polygon from a row with 4 coordinates
1246
02-04-2020 03:00 PM
PaulRabatin1
I have a excel file with multiple sheets.  one sheet called polygons contains rows with the fields:  name, description, startlatN, startlonW, startlatS, startlonW, endlatN, endlonE, endlatS, endlonE
the start and ends have decimal degrees latitude and longitude values.  I'm trying to find a way to plot the four points and convert to polygon without useing xytoevent then pts to line then line to polygon.  I thought there was a tool in toolbox which did in line polygon creation.   thanks
DavidPike
MVP Notable Contributor
Look at the arcpy.Polygon object. Can easily pass an array into it to create your polygons.
DavidPike
