loop through a folder with text files
6633
12
01-30-2020 05:46 AM
MarkBalman
Hi all
I am stuck with how to loop through a folder containing numerous text files containing lat and long values. The idea is to open a text file, create an XY layer and then append the result into a layer within a geodatabase. I can do the following which takes a single text file, creates the xy layer and then appends this xy layer to the geodatabase layer:
# XYTableToPoint.py
# Description: Creates a point feature class from input table
# import system modules
import arcpy
# Set environment settings
arcpy.env.workspace = r"C:\Projects\points\test.gdb"
# Set the local variables
in_table = r"D:\points\split_data\file_1.txt"
out_feature_class = "file1"
x_coords = "field7"
y_coords = "field6"
z_coords = ""
# Make the XY event layer...
arcpy.management.XYTableToPoint(in_table, out_feature_class,x_coords, y_coords, z_coords,
arcpy.SpatialReference(4326))
# Print the total rows
print(arcpy.GetCount_management(out_feature_class))
arcpy.management.Append("file1", r"C:\Projects\points\test.gdb\all_Points", "NO_TEST", 'id "id" true true false 25 Text 0 0,First,#,file1,Field1,0,8000;individualCount "individualCount" true true false 15 Text 0 0,First,#,file1,Field2,0,8000;year "year" true true false 4 Long 0 0,First,#,file1,Field3,-1,-1;month "month" true true false 2 Short 0 0,First,#,file1,Field4,-1,-1;country "country" true true false 255 Text 0 0,First,#,file1,Field5,0,8000;decimalLatitude "decimalLatitude" true true false 8 Double 0 0,First,#,file1,Field6,-1,-1;decimalLongitude "decimalLongitude" true true false 8 Double 0 0,First,#,file1,Field7,-1,-1;Name "Name" true true false 100 Text 0 0,First,#,file1,Field8,0,8000', '', '')
This works fine but this would be tedious to do edit and rerun manually for each file (potentially over a 1000 files).
Any advice most welcome.
Mark
DavidPike
MVP Notable Contributor
import arcpy, os
in_folder = whatever your folder is
merged_fc = name of final merged fc to be created in gdb
x_coords = "field7"
y_coords = "field6"
z_coords = ""
#grab all the text files and put them in  a list
text_file_list = [ ]
for file in os.listdir(in_folder):
    if ".txt" in file:
        text_file_list.append(file)
# Make the point feature classes
path_list = [ ]
for text_file in text_file_list:
    in_table = os.path.join(in_folder,text_file)
    name = text_file.strip(".txt")
    out_fc = os.path.join("in_memory",name)
    path_list.append(out_fc)
    arcpy.management.XYTableToPoint(in_table, out_fc,x_coords, y_coords, z_coords, arcpy.SpatialReference(4326))
arcpy.Merge(path_list,merged_fc)
arcpy.Delete_management("in_memory")
George_Thompson
Esri Notable Contributor
Not Python so to speak but another option would be to use the LocateXT functionality within ArcGIS Pro; What is LocateXT—ArcGIS Help | ArcGIS Desktop
That may be easier to adjust. There is also more functionality coming out with the next release at ArcGIS Pro 2.5.
--- George T.
MarkBalman
Thank you George,
Not tried Locate yet but will have a look when I have some spare time.
Best regards
Mark
MarkBalman
Hi George, Locate looks interesting but sadly we don't have a license for it.
Best wishes,
Mark
JoshuaBixby
MVP Esteemed Contributor
Python has several ways to find TXT files on a file system:  Find all files in a directory with extension .txt in Python - Stack Overflow
MarkBalman
Hi Joshua
Thanks for the suggestions, will try these once I have more time to spend on the task
Best regards
Mark
LorneDmitruk2
Use the arcpy.da.Walk function to loop through the files.
MarkBalman
Hi Lorne
Thank you for the suggestion. Am quite new to python so have yet to try this method
Best regards
Mark
DavidPike
import arcpy, os
x_coords = "field7"
y_coords = "field6"
z_coords = ""
    if ".txt" in file:
path_list = [ ]
MarkBalman
Thank you David,
I tried this but got error message which I am trying to work out (will be trying again next week)
Best regards,
Mark
