My default values stopped working?
806
01-27-2020 03:59 PM
KyleGjeruldsen
All my surveys have stopped populating the default values.  these have been woriking for a couple months, but just up and stopped.  Any ideas what to look at?
IsmaelChivite
Esri Notable Contributor
Hi Kyle Gjeruldsen‌  I am not sure we have enough info to help you out here. The behavior of defaults has not changed recently. I am guessing you are using the Survey123 field app? Or are you using a web form? Can you share your form? May be a link to your form, or a link to your XLSForm?
KyleGjeruldsen
Using Survey123 Connect 3.7.60.
It's just strange that everything had been working for several months and then I started having problems (I thought) with the script that sends out status emails.  I had been trying to troubleshoot the email script, when I figured out the status wasn't being populated with default values.
DougBrowning
MVP Esteemed Contributor
With hidden type I think using calculation column works better.
