How do I convert seconds to minutes, hours, or days with Arcade
3186
01-21-2020 12:25 PM
JacobCaldwell
 Currently our data displays in seconds, but I'd like to set it to display in minutes, hours, or days so that it's easier to read in the pop-up. How can I accomplish this with Arcade?
XanderBakker
Esri Esteemed Contributor
Hi jakecaldwell_ETISoftware ,
Have a look at the example below:
var seconds = 90061;
var result = "";
var days = Floor(seconds / (60 * 60 * 24));
if (days > 0) {result = Round(days,0) + " day(s) "};
seconds -= days * 60 * 60 * 24;
var hours = Floor(seconds / (60 * 60));
seconds -= hours * 60 * 60;
var minutes = Floor(seconds / 60);
seconds -= minutes * 60;
result += Text(hours, "00") + ":" + Text(minutes, "00") + ":" + Text(seconds, "00");
return result
This returns:
1 day(s) 01:01:01
Just assign the seconds field to the seconds variable on line 1.
XanderBakker
var result = "";
return result
This returns:
1 day(s) 01:01:01
JacobCaldwell
 This worked great! Thanks!
XanderBakker
Hi jakecaldwell_ETISoftware , I'm glad it does. You can tweak the way you want to present the results. If you have any additional questions, just post them here and I will get back to you.
