How Search Widget can work with Client Side Layer?
1109
01-21-2020 02:42 PM
RoelGarcia
Hi Friends,
I have a client side layer (NOT coming from ArcGIS Server / AGOL) and I added it to the Search widget but the searching process for that layer info does not work...
Process:
Creating Feature Layer on the client side (NOT coming from ArcGIS Server or AGOL)
* Adding the Layer to the map
* Adding the Layer to Search Widget Source
* Populating the Layer from external API data
I am using ArcGIS JS API 3.x
Is anyone know how can I integrate a Client Side Layer to the Search Widget?
Roel
Tags (1)
RobertScheitlin__GISP
Roel,
   To my knowledge that is not possible out of the box.  The search dijit states, when using a featurelayer.
a 10.3 or later feature layer that supports pagination, i.e. supportsPagination = true.
That is not something a clientside featurelayer has the capability of.
Noah-Sager
Robert is correct, the Search dijit requires either a geocode service or a hosted feature layer.
https://developers.arcgis.com/javascript/3/jsapi/search-amd.html#sources
https://developers.arcgis.com/javascript/3/jssamples/search_multiplesources.html
So I do not believe that it can work with a client-side feature layer.
