Attribute Expressions in Table View in Web Map
1196
01-17-2020 04:44 AM
MaryEllen_Perko
Hi.  Does anyone know how to remove a field created through an attribute expression from the table in a saved web map or through the feature layer visualization?  I've got several derived fields for popup formatting that I do not want to appear in the table.  But even if I have them unchecked in the attribute configuration they still show up.
Thanks.
by Anonymous User
Not applicable
Hi Mary Ellen,
You can hide fields in the web map attribute table through the Item Details > Visualization > Configure pop-up dialog > configure attributes > hide the desired fields > OK > OK > Save Layer. Then reload the web map and open the attribute table and you should see that the fields are hidden.
Hope that helps,
-Peter
