ARCMAP 10.5 Python Script Error
2127
01-15-2020 11:50 PM
MudassarAli2
I have successfully created the following code which is running fine on my system (Arcmap 10.5)
https://onlinegdb.com/SkvkqiWeU
This code is running fine on my system but giving following error on some other system,
Executing: script "G:\image\s.img" "G:\river_splitted" "G:\output"
Start Time: Tue Jan 07 09:40:43 2020
Running script script...
Failed script script...
File "E:\script.py", line 53, in <module>
arcpy.gp.ExtractMultiValuesToPoints_sa(point_feature, DEM + " elevation", "NONE")
File "c:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\geoprocessing\_base.py", line 510, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
RuntimeError: Object: Error in executing tool
Failed to execute (script).
Failed at Tue Jan 07 09:40:45 2020 (Elapsed Time: 2.11 seconds)
DanPatterson_Retired
MudassarAli2
There is no syntax highlighter option available in the text editor, I am using the google chrome. Thats why I have pasted the code on a link, you can check it out at https://www.onlinegdb.com/SkvkqiWeU
SC = arcpy.SearchCursor(min_elevation)
field_name = 'MIN_elevation'
for row in SC:
    value=row.getValue(field_name)
    # Process: Raster Calculator
rastercalc=arcpy.sa.Raster(constant_raster_)*float(value)‍‍‍‍‍
.... the rest
line 53 is the blank link, (line 5 above)
Copy your code and use the syntax highlighting in my link. since the row error number doesn't match
JoeBorgione
In addition to Dan's thread, there are others explaining the use the syntax highlighter; it's a function of geonet, not your browser:
Posting code with Syntax Highlighting on GeoNet
https://community.esri.com/thread/245173-error-999999-in-arcpy-after-arcgis-pro-crashes
