Formatting Question
565
01-15-2020 10:53 AM
MichelleDuncan2
Can anyone tell me how to format the excel spreadsheet in Survey123 so I don't get double quotes for what should be an inch symbol? I'm pulling data from the info.csv table to populate fields. See example attached.
Tags (1)
Jim-Moore
Hi Michelle
When working on a CSV in Excel, it can enclose text strings in double quotes " " (particularly if the string contains spaces). The quote mark used in the string (used for inches) could be confusing things. Try opening the CSV in a text editor to see if it shows something like "CROSS PLATE ANCHOR 24""". A simple fix would be to find/replace all the triple quotes with double quotes in the text editor.
Hope this helps
Best,
Jim
