Unable to create a new user via ArcGIS API
3847
01-14-2020 06:58 AM
DuncanHornby
MVP Notable Contributor
All,
I am exploring some scripting of the ArcGIS API for Python in the hope I can automate some future scenario. I have an administrator role on ArcGIS Online.
All I am trying to do is create a user that is a viewer as we have some unused viewer licenses to test with. My code is simply this, where xxx,yyy are my username and password.
from arcgis.gis import GIS
# User name is case sensative as is password!
gis = GIS("https://geodatainstitute.maps.arcgis.com","xxx","yyy") # https://www.arcgis.com
print(gis.users.counts('user_type')) # This line runs OK
print("create a new user")
newuser = gis.users.create(username='testuserxxx', password='q1w2e3r4t5y6,.<>', firstname ='Firstxxx', lastname = 'Secondsxxx', email = '[email protected]' , role='org_user', level=1, provider = 'arcgis')
if newuser is None:
 print("FAILED!")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
It always returns this:
create a new user
Unable to create testuserxxx
FAILED!
What am I doing wrong? I have followed the example as shown here. I have also tried connecting to https://www.arcgis.com  but I still get the same error.
Is there some setting on AGOL that needs turning on/off, have I set up the role/level correctly? If one looks at the UserManager class on the API help file it confusing indicates that user_type is a required parameter but that seems not the case?
Any help or advice would be much appreciated.
Duncan
DuncanHornby
Hi Adrian,
I've been playing around with my very simple code above as no one offered up any pearls of wisdom... You would think ESRI staff would be all over this. Anyway this finally worked...
newuser = gis.users.create("testuserxyz","1234567890QWERTYuio","Dumbo","Dumbo2","[email protected]",None,None,"arcgis",None,1,None,"viewer")
The issue seemed to be with the password length and characters. Try something like above.
The only other difference was that I was running the code from within the Python command line window in Pro.
Hope that helps!
AdrianHughes3
I'm also having this issue, even when trying the example code, shown here
DuncanHornby
Hi Adrian,
Hope that helps!
AdrianHughes3
Thanks Duncan
I still get the same error with your code, running from both jupyter notebook and python window in pro
AFackler_NAPSG
For friends who come across this later and grit your teeth on why this won't work, I found that my organization only allowed the user type "Creator" with a custom role. When the user type and role were modified to be exactly what the org required, it worked like a charm.
