CityEngine "Get Map Data" Map Not Show Up
4550
10
01-12-2020 04:57 PM
WensupYang
Hi, I'm new to CityEngine and I'm trying to use it for a Designothan to build a 3D modle of my local neighborhood.
I login successfully, but when I click Get Map Data, the dialogue shows up but no map info shows up. I check my internet and that doesn't seem to have a problem. Any help would be much appreciated!
Best,
Wen
WensupYang
Hi, Luiz
Thank you for trying to help me out.
My CE version is Esri CityEngine 2019.1.5704 (Build Date: 190903, release, macosx-64bit). I believe it is the newest one.
I checked the connectivity. No problem there.
I also tried to start a new project with No preset coordinates system. Still not working.
I appreciate your help!
AnastasiaAndreasen
Hi Wen, I have the same problem. Did you manage to find the solution?
TokyoSteve
Did you find a solution to this probelm. Cant figure it out myself :S
TatiannaSwenda1
I am having the same issue. Using 2019.1 version.  Online connection ok.  Get map data feature is not working regardless of whether the scene has a coordinate system assigned. #GetMapDataFeatureNotWorking
MohammadsaleemZaheer
you must be signed in to an arcgis online portal to download elevation data. i have see this warning . how we fix it? Thank you.
Rob1821
Have you find the solution?
yjiang
I still have this problem. Is there any solutions?
anthonysirna
I'm having the same problem. Has anyone found a solution?
