Add new Selection (Clone Graphics)
2554
12-23-2019 05:43 AM
Vakhtang_Zubiashvili
Hi Guys, i have Polygon Feature class. I want to make selection for multiple feature ( i use "hitTest", but code i have does not work. I took code from here jsapi 4.0 popup: set highlight graphic on feature layer click? .
I use simpleLineSymbol for graphicsLayer.
Help me please.
And if you can tell me how to unselect feature i do not need after selection.
Here is my code:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>GWP - მილი და სამისამართო ერთეული</title>
  <style>
    html,
    body,
    #viewDiv {
      padding0;
      margin0;
      height100%;
      width100%;
    #info {
      background-colorblack;
      opacity0.75;
      colororange;
      font-size18pt;
      padding8px;
      visibilityhidden;
  </style>
<link rel="stylesheet" href="https://js.arcgis.com/4.13/esri/css/main.css">
<script src="https://js.arcgis.com/4.13"></script>
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/layers/FeatureLayer",
      "esri/renderers/UniqueValueRenderer",
      "esri/symbols/SimpleLineSymbol",
      "dojo/dom",
      "dojo/domReady!"
    ], function(
      Map,
      MapView,
      FeatureLayer,
      UniqueValueRenderer,
      SimpleLineSymbol,
      dom
    const labelClass = {
          // autocasts as new LabelClass()
          symbol: {
            type: "text"// autocasts as new TextSymbol()
            color: "black",
            haloColor: "black",
            font: {
              // autocast as new Font()
              family: "Playfair Display",
              weight: "bold"
          labelPlacement: "always-horizontal",
          labelExpressionInfo: {
    expression: "$feature.g_dasaxeleba_ka"
      var renderer = {
  type: "simple"// autocasts as new SimpleRenderer()
  symbol: {
    type: "simple-fill"// autocasts as new SimpleFillSymbol()
    outline: {
      // makes the outlines of all features consistently light gray
      color: "red",
      width: 0.5
     var linefeatureLayer = new FeatureLayer({ url:"http://xx.xx.xx.xx:6080/arcgis/rest/services/test/Tbilisi_wyalmomarageba_keti/MapServer/16",
     select: false
      var layer = new FeatureLayer({
        url: "http://xx.xx.xx.xx:6080/arcgis/rest/services/test/samisamarTo/FeatureServer/0",
        outFields: ["*"],
        labelingInfo: [labelClass],
        renderer: renderer
      var map = new Map({
        basemap: "dark-gray",
        layers: [layer/*linefeatureLayer*/]
      var view = new MapView({
        container: "viewDiv",
        map: map,
        center: [44.750241.725524],
          zoom: 12
      view.ui.add("info""top-right");
      // Set up a click event handler and retrieve the screen x, y coordinates
      view.on("click"function(event) {
        // the hitTest() checks to see if any graphics in the view
        // intersect the given screen x, y coordinates
        view.hitTest(event)
          .then(getGraphics);
      function getGraphics(response) {
        // the topmost graphic from the click location
        // and display select attribute values from the
        // graphic to the user
        var graphic = response.results[0].graphic;
        var attributes = graphic.attributes;
        var category = attributes.g_dasaxeleba_ka;
        var wind = attributes.kodi;
        var name = attributes.SE_ID_new;
        dom.byId("info").style.visibility = "visible";
        dom.byId("name").innerHTML = name;
        dom.byId("category").innerHTML = "დასახელება: " + category;
        // symbolize all line segments with the given
        // storm name with the same symbol
        var renderer = new UniqueValueRenderer({
          field: "SE_ID_new",
          defaultSymbol: layer.renderer.symbol || layer.renderer.defaultSymbol,
          uniqueValueInfos: [{
            value: name,
            symbol: new SimpleLineSymbol({
              color: "orange",
              width: 5,
              cap: "round",
        layer.renderer = renderer;
      view.graphics.removeAll();
                    if (graphic) {
                        var selectionGraphic = graphic.clone();
                        selectionGraphic.symbol = renderer;
                        view.graphics.add(selectionGraphic);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
  <div id="info">
    <span id="name"></span><br>
    <span id="category"></span><br>
    <span id="wind"></span>
  </div>
</body>
</html>
AnneFitz
I updated that sample to select multiple features when you click, here is the codepen: https://codepen.io/annefitz/pen/GRgmPVJ
Hopefully this helps!
AnneFitz
This sample in our SDK might be helpful to understand how to use hitTest(): Access features with pointer events
Dear Anne, thank you, i use hitTest, but i wany to select multiple features on click. I saw o need clone, but i could not success do it.
AnneFitz
Thank very you Anne, i did it.
Merry Christmas and happy new Year.
