ArcGIS Pro logon error
15834
26
12-20-2019 07:32 AM
Dannyde_Groot
When I am logging in with my social account (Google) from my ArcGIS Pro to my Organization, I get a Javascript error and I am unable to login. Anyone same issues or solutions? #ArcGIS Pro #javascript error #social account
RichardAlden
We have published a workaround for ArcGIS Pro. Please see the Knowledge Base article 000022667. A similar workaround is forthcoming for ArcMap users.
JacobHelfman1
Are the Google account credentials the same as your AGOL credentials?
Dannyde_Groot
Hi Jacob,
Yes they are and logging in to my organization works perfectly.
JacobHelfman1
What version of ArcGIS Pro are you using and what exactly do you see when you try logging on?
Dannyde_Groot
I am using ArcGIS Pro 2.4.3 and I have included two screenshots.
JacobHelfman1
Interesting. Do these any of these bugs (Release notes for ArcGIS Pro 2.4—ArcGIS Pro | Documentation) apply to your situation?:
BUG-000106357
Unable to make a connection from ArcGIS Desktop using database authentication login if the password contains the } character.
BUG-000116524
Currently borrowed ArcGIS Pro extensions do not allow other login accounts to use the extensions when disconnected from the License Manager.
If that doesn't work, I would see if it's possible to change my Google settings, like Content or Privacy sections (Settings > Show Advanced Settings)
Dannyde_Groot
Hi Jacob,
I do not have any special characters in my password and don not use a License Manager. My setup is a ArcGIS for Personal Use with a AGOL-organization.
I have also contacted Esri Support, they believe it is a Google JavaScript error and not related to ArcGIS Pro. I also think it is related to security enhancements from Google which is a good thing, but annoying for me.
I have requested Esri support if they can transform my account to a regular username/password account.
Regards,
Danny de Groot
Outlook for Android<https://aka.ms/ghei36> downloaden
JacobBlankenship1
I am having the same problem, was Esri able to fix the problem?
Dannyde_Groot
Hi Jacob,
Esri has been busy with this problem, I have sent them a Fiddler trace of the network traffic. They believe the sign in process is attempting a two facor authentication. I have not enabled this for my Google account and am waiting for them to reply.
Regards,
Danny de Groot
MadisonMays
Esri Technical Support has logged BUG-000127774 Signing into ArcGIS Pro with an ArcGIS Online account that uses Google to sign in fails with the errors "An error has occurred in the script on this page" and "Google couldn't sign you in." We are currently looking into this issue. If you encounter this issue, I encourage that you submit a support ticket so that we can get you attached to this bug.
Thank you,
Madison
