ArcGIS Pro logon error
15812
26
12-20-2019 07:32 AM
Dannyde_Groot
When I am logging in with my social account (Google) from my ArcGIS Pro to my Organization, I get a Javascript error and I am unable to login. Anyone same issues or solutions? #ArcGIS Pro #javascript error #social account
JoshBarry
Hi Madison,
I have the exact same problem as Danny stated above! I tried to find the Bug on the Esri Technical Support page but it's not listed there. Do you know in how long you will get a step-by-step process to find the solution?
Thank you,
Josh
RichardAlden
DanielEvans1
I'm also having this problem. How the hell do I raise a support ticket? When I try it keeps telling me I don't have access to my own organisation!?
George_Thompson
Esri Notable Contributor
You need to have your My Esri admin grant you the permissions to submit support tickets.
--- George T.
StuartMoore
we're getting the same issue today but we don't use google, also we are getting login issues in survey123 we just get a blank page when clicking sign in.... i think it might be down to our network thought...
Stu
RosieTempest1
I had this exact same problem. Got around it by signing into my gmail account on Internet Explorer so ArcGIS Pro can skip the authentication. Doesn't fix the underlying problem but at least I can use the application now. Hope this helps.
Brian_JeremyEdgar
I am currently having the same issue. The license type is "Named user license". I purchased the ArcGIS while I logged in on chrome with my google account. I assumed I have to login to the ArcGIS Pro app with my google account as well but the script error comes up. I tried logging into my ArcGIS account on Chrome and Internet Explorer first before i tried logging in the app but it still wouldn't work. Anyone found a solution yet?
ArcGIS Pro script error - trying to sign in using google account
RosieTempest1
Have you tried logging on to your Google account (not just your ArcGIS account) on Internet Explorer?
HankArnold
Yes, I am another who was foolish enough to use Google to log in to Esri.
Same error
My Google Log in works everywhere but ESRI.
Tried Microsoft Edge and Internet Explorer
Have logged several tech requests including asking ESRI to allow me to log in normally because we had to do some account maintenance and it wouldn't allow me to log in to make changes.
I'm told there is no option to change the log in method. Its yours with that UserName forever.
Support finally suggested I set up a second log in an then linked it to some parts of the original authorization set so I could make the required changes, but twice now in the past several weeks I have hit authorization problems that seem to me to be related to my new login not having the permissions of the old one.
Support says its an account issue and my account rep says is a support issue.
I finally gave up.
The only work around I can think of, other than ESRI fixing the problem, is to start a new account and pay for everything all over again.
RichardAlden
We have published a workaround for ArcGIS Pro. Please see the Knowledge Base article 000022667. A similar workaround is forthcoming for ArcMap users.
