Basic substr string parsing question
1469
12-18-2019 03:42 PM
LS1
I am using select_one that returns a string containing a  number (unknown number of digits) followed by a '-' followed by a text string. How do I use substr to parse out the number before the '-'.  It can be any number between 1 and 999.
For example "10-Lincoln Center Parkway" I just want to use the number 10 in pulldata call to look up additional information.
Jim-Moore
Hi Lisa
One way to achieve this would be to use substr() with nested if statements. Luckily in this case you only have three scenarios (i.e. one-, two- or three-digit number) so the calculation shouldn't be too cumbersome! Check the postion of the "-" separator to work out how many digits, then return the first 1, 2 or 3 characters as applicable. For example:
if((substr(${address1},1,2)='-'),substr(${address1},0,1),if((substr(${address1},2,3)='-'),substr(${address1},0,2),if((substr(${address1},3,4)='-'),substr(${address1},0,3),'')))
Alternatively, you could use regular expressions in each if statement to match the pattern. For more info on regex please see: Formulas—Survey123 for ArcGIS | Documentation.
Hope this helps
Best,
Jim
