Arcade - Intersecting Polygons - return multiple answers if multiple.
3478
11
12-12-2019 10:47 AM
TrishaSchlake
Hi Xander Bakker
I have a parcel feature layer and a soils feature layer in my webmap. I'm trying to apply the arcade to my parcels layer so that when a parcel is clicked it will give me the corresponding soils to that parcel. The issue is that there could be more than one soil per parcel. The expression I currently have applied to my parcel feature class is this:
 var intersectLayer = Intersects(FeatureSetByName($map,"STATSGO2Soils"), $feature)
for(var f in intersectLayer){
return f.muname
But it will only return one of my soils into the parcel and will not bring in multiple soils names. Is there a way to do what I'm hoping to do?
KenBuja
MVP Esteemed Contributor
Try this instead.
var results = "";
  if (results == "") {
    results = f.muname;
  } else {
    results += ", " + f.muname;
return results;‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
This would be another way
var results = [];
  results[Count(results)] = f.muname;
return Concatenate(results, ", ");‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
KenBuja
Try this instead.
var results = "";
    results = f.muname;
  } else {
var results = [];
Amarz
@KenBuja
This is a very helpful code, but I am wondering is there a way to add a -1ft buffer or something? I am getting all polygons that share a border with the parcel but are not necessarily in the parcel.
Also would it be possible to add an OrderBy ASC to the script?
KenBuja
You can use additional chaining to add those extra functions to get the intersect layer
var intersectLayer = OrderBy(
  Intersects(
    Buffer(
      FeatureSetByName(
        $map,
        "STATSGO2Soils"
      -1,
      'feet'
    $feature
 'Muname DESC'
Amarz
Thanks for coming back to this Ken!
Amarz
Hey Ken, sorry to come back, I am attempting to utilize this section in the above script using my own values but am getting the following error:
Invalid Expression. Error on line 19. Identifier expected.
  Intersects(
    Buffer(
      FeatureSetByName(
        $map,
        "STATSGO2Soils"
      -1,
      'feet'
    $feature
 'Muname DESC'
var results = [];
return Concatenate(results, ", ");‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Any advice?
KenBuja
My apologies...I had the syntax incorrect. Give this a try (using your own layer and field names)
  Intersects(
    FeatureSetByName($map, "other layer"),
    Buffer($feature, -1, "feet")
  "sortField DESC"
var results = [];
for (var f in intersectLayer) {
  results[Count(results)] = f["displayField"];
var output = Concatenate(results, ", ");
Amarz
Any idea what is causing the following error? I ran the Check Geometry on both layers participating in this intersect with 0 errors.
ERROR 002717: Invalid Arcade expression, Arcade error: Invalid search geometry, Script line: 9
Failed to execute (CalculateField).
KenBuja
Could you post your code to see what's on line 9? I'm wondering if there's a null geometry in your data. I tested this on the USA States and USA Major Cities dataset from the Living Atlas and didn't get any errors.
Amarz
Deleting previous chat cause it wasn't relevant.
@KenBuja Thank you for all your help! I figured it out. The layer I was using had the ever dreaded Slivers in it that were less than 1ft causing the geometry error.
The code it working as expected when I reduced the negative buffer.
Thank you so much!
