Add layer from geodatabase file
3436
14
12-10-2019 06:50 AM
jaykapalczynski
Honored Contributor
I created a geodatabase via ArcGIS Runtime Content in ArcMap.
I am trying to add it via this reference: Create an offline map—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
BUT map.addLayer does not exist or its giving me an error
Any ideas?
//Declare the geodatabase
Geodatabase {
        path: "/path_to_my_geodatabase/mydata.geodatabase"
FeatureLayer {
        featureTable: geodatabase.geodatabaseFeatureTableByLayerId(0);
map.addLayer(featureLayer);
ErwinSoekianto
Esri Alum
Jay,
Based on the sample Feature Layer (Geodatabase),
- AppStudio Sample - arcgis-appstudio-samples/MyApp.qml at v4.0 · Esri/arcgis-appstudio-samples · GitHub
- ArcGIS Runtime Qt/QML Sample - Feature layer (geodatabase) | ArcGIS for Developers
You don't need to call addLayer if you initialize the FeatureLayer inside Map, that layer is already added.
Looping in ArcGIS Runtime SDK for Qt‌, to see why addLayer is throwing an error.
Thank you,
Erwin
jaykapalczynski
Honored Contributor
Forgot to add I am using QML for AppStudio
ErwinSoekianto
Esri Alum
Jay,
Thank you,
Erwin
LucasDanzinger
Esri Frequent Contributor
There is no addLayer method on Map. Instead, you can nest the layer inside the Map like you mentioned, or you can call map.operationalLayers.append(), and add the layer via that method LayerListModel QML Type | ArcGIS for Developers .
jaykapalczynski
Honored Contributor
can I still reference the index of the gdb like this
featureTable: geodatabase.geodatabaseFeatureTableByLayerId(4);
OK going to test that now.  THANKS
jaykapalczynski
Honored Contributor
Think I got it...THANK YOU SO MUCH.....
Seems I could not use
featureTable: gdb.geodatabaseFeatureTableByLayerId(4);
But had to use
featureTable: gdb.geodatabaseFeatureTablesByTableName["WMAs_1"];
import QtQuick 2.6
import QtQuick.Controls 2.2
import QtQuick.Layouts 1.3
import Esri.ArcGISRuntime 100.6
//import Esri.ArcGISExtras 1.1
Rectangle {
    width: 800
    height: 600
    property string errorMessage: ""
    signal previous(string message)
    property string lecaDataPath:  app.mmpkManager.fileUrl3
    // Map view UI presentation at top
    MapView {
        anchors.fill: parent
        Rectangle{
            width: 300
            height: 50
            Column{
                width: 300
                spacing: 0
               Text {
                  text: lecaDataPath
                  width: 300
                  wrapMode: Text.WordWrap
        Map {
            // set an initial viewpoint
            ViewpointCenter {
                Point {
                    x: -8778929
                    y: 44521052
                    spatialReference: SpatialReference { wkid: 3857 }
                targetScale: 35e4
            BasemapTopographic {}
            //! [FeatureLayer Geodatabase create]
            // create a feature layer
            FeatureLayer {
                // obtain the feature table from the geodatabase by name
                //featureTable: gdb.geodatabaseFeatureTableByLayerId(4);
                // create the geodatabase
                Geodatabase {
                    path: lecaDataPath
                    onErrorChanged: errorMessage = error.message;
    Dialog {
        modal: true
        x: Math.round(parent.width - width) / 2
        y: Math.round(parent.height - height) / 2
        standardButtons: Dialog.Ok
        visible: text.length > 0
        property alias text : textLabel.text
        property alias informativeText : detailsLabel.text
        ColumnLayout {
            Text {
                text: errorMessage
            Text {
                text: "Please consult the README.md"
jaykapalczynski
Honored Contributor
Any idea how to read this geodatabase and or get a list of the features that it contains?
LucasDanzinger
You could loop through the geodatabaseFeatureTables list:
Geodatabase {
    path: dataPath + "geodatabase/LA_Trails.geodatabase"
    onErrorChanged: console.log(error.message)
    onLoadStatusChanged: {
        if (loadStatus === Enums.LoadStatusLoaded) {
            console.log("number of feature tables:", geodatabaseFeatureTables.length)
            for (var i = 0; i < geodatabaseFeatureTables.length; i++) {
                var ft = geodatabaseFeatureTables[i];
                var fl = ArcGISRuntimeEnvironment.createObject("FeatureLayer", {featureTable: ft});
                map.operationalLayers.append(fl);
    Component.onCompleted: load()
jaykapalczynski
Honored Contributor
So your example would read the geodatabase and create multiple Feature Layer objects to display the multiple features in the geodatabase?
LucasDanzinger
yes that is what this example does.
