PermissionError
1564
5
12-05-2019 05:38 PM
LinoSun
Dear all
I have issue when using arcgis.learn.detect_objects() function,
updateParameters Syntax Error: Traceback (most recent call last):   File "C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\Resources\ArcToolBox\Services\RasterAnalysisTools.tbx#DetectObjectsUsingDeepLearning.UpdateParameters.py", line 1, in <module>   File "c:\program files\arcgis\server\framework\runtime\arcgis\Resources\arcpy\arcpy\__init__.py", line 21, in <module>     import numpy   File "C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\Lib\site-packages\numpy\__init__.py", line 148, in <module>     from . import fft   File "C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\Lib\site-packages\numpy\fft\__init__.py", line 21, in <module>     import mkl_fft._numpy_fft as _nfft   File "<frozen importlib._bootstrap>", line 971, in _find_and_load   File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked   File "<frozen importlib._bootstrap>", line 665, in _load_unlocked   File "<frozen importlib._bootstrap_external>", line 674, in exec_module   File "<frozen importlib._bootstrap_external>", line 780, in get_code   File "<frozen importlib._bootstrap_external>", line 832, in get_data PermissionError: [Errno 13] Permission denied: 'C:\\Program Files\\ArcGIS\\Server\\framework\\runtime\\ArcGIS\\bin\\Python\\envs\\arcgispro-py3\\Lib\\site-packages\\mkl_fft\\__init__.py'  Failed.
But why does this error occur and how to solve it
LinoSun
Thank you for any idea. Earl MedinaAtma ManiRohit Singh
PriyankaTuteja
Hi Lino, What version of ArcGIS server are you using?
LinoSun
PriyankaTuteja
Can you also please share the code you have used to create the detect_model object.
LinoSun
Many thanks.
