How to remove gaps in one polygon
1577
12-04-2019 11:30 AM
by Anonymous User
Not applicable
I am trying to make metersheds from a parcel layer. I want it to be one continuous polygon with no gaps throughout it. Is there a way to do this without having to re-draw every basin? I have tried using Interpolate and also Aggregate Polygon.
JoeBorgione
If you have an advanced license you can try the minimum bounding geometry with the convex hull option.  I just did it Pro. First merge all your metersheds into one polygon and then apply the tool.  You'll still need to do some trimming:
My original:
Minimum Convex Hull:
Trim to your liking:
