Saving Disabled for Attribute Rules
2514
11-27-2019 10:48 AM
AdrianLaufer
I'm creating a feature class to use for data collection and want to apply a number of attribute rules for immediate calculation. I have no trouble defining the attribute rules in ArcGIS Pro, but it will not let me save them. Each time I get the following message:
I've tried this multiple times and cannot get it to work. I'm positive that there are no unsaved feature edits. Please help!
JohnGargiulo
Same issue here
AdamEversole1
Hi Adrian,
My name is Adam, I work with Esri Support, and am working on a open support case @John Gargiulo on this issue.
We suspect this could be a issue with ArcGIS Pro 2.4.  Or with the location of the Geodatabase.
Questions:
-What Version of ArcGIS Pro are you using? if 2.4 Have you tried 2.5?
-Can you identify the full path to the Geodatabase? is that drive local to the computer or on a server?
We appreciate your input, it will help the investigation.
Cheers,
-Adam
AdamEversole1
Hi Adrian,
I wanted to follow up on this topic. The Save option would be disabled because Attribute Rules are "read only" if you have a basic licence.
Attribute Rules Save button disabled
Another note here is that at ArcGIS Pro 2.5 the software will present a warning message below. In 2.4 this message was absent.
I hope this helps, Please "@" me if you have any questions.
Thanks You,
-Adam
