can Dashboard URL parameter select (not filter) category selector?
4150
11-26-2019 06:59 AM
ChelseaRozek
MVP Regular Contributor
I thought I had this working at some point, but I'm not seeing how to do it now and it doesn't seem to be possible. I've set up a URL parameter in my operations dashboard to accept param=MUNICIPALITYNAMEHERE. The only action choice for category parameter is Filter. I can Filter the Category Selector I have in my header which is set to filter all the other widgets and charts to show stats for that municipality. Unfortunately, this is a FILTER on the category selector, so then it will only show that one MUNICIPALITYNAME and the user can't navigate between them. Is there any way to get the URL parameter to not filter, but just select that choice from the category selector so that all the other values remain in the dropdown? I don't see the point of filtering the category selector with the URL parameter, it just limits functionality in the dashboard.
I could configure the URL parameter to filter all the widgets in the dashboard itself, but then the category selector shows the wrong municipality and would confuse the end user.
What I want, all the choices still there:
What I get when I pass param=City of Saline:
DerekLaw
Esri Esteemed Contributor
Hi Chelsea,
I've checked with the Dev team and the functionality you're asking for is not currently supported by the Action framework in Operations Dashboard.
Can you please post an enhancement request on the ArcGIS Ideas site for Ops Dashboard so we can gauge interest from the community?
Hope this helps,
DerekLaw
Hi Chelsea,
Hope this helps,
ChelseaRozek
Hi Derek, thanks so much for checking with them! I'll make the idea right now
Here's the idea:  Allow Operations Dashboard URL parameter to SELECT... - GeoNet, The Esri Community
AnthonyJonesRSK
Hi Derek, it's been 4 over years since this post but is this kind of functionality (to select a category via url rather than filter) on the dashboard development road map? I notice that you suggested Chelsea post this as an idea but in the 4 years since they posted their idea there has been no response from Esri on this and the idea simply shows as Open despite there being a number of customers asking for this enhancement. Any kind of update on this would be very much appreciated. Thanks
