Adding Javascript API widget to Esri's Angular CLI boilerplate code
2432
11-23-2019 10:38 PM
JacobHelfman1
I'm using the Esri Angular CLI template from Github here: GitHub - Esri/angular-cli-esri-map: Example Angular component for building mapping applications with... . I've been trying to understand how I can add a widget to the app, in the esri-map.component.ts file. I've added the appropriate code for the BasemapToggle widget within the "async ... try {..." and after the "const mapViewProperties:..." parts like so:
      Add Widgets
     const basemapToggle = new BasemapToggle({
      view: mapViewProperties,  // The view that provides access to the map's "satelite" basemap
      nextBasemap: "topo"  // Allows for toggling to the "hybrid" basemap
      //add the widget to the top right of the view
      mapViewProperties.ui.add(basemapToggle, "top-right");
But after that, I get a window in Visual Studio Code saying "any: Property 'add' does not exist on type 'DefaultUIProperties'", even though it looks like add() is mentioned in the documentation: https://developers.arcgis.com/javascript/latest/api-reference/esri-views-ui-DefaultUI.html.
The code is attached. Any guidance whatsoever would be greatly appreciated.
by Anonymous User
Not applicable
Maybe this response will help others....
Add the widget to the mapview in the mapView.when(() => {  callback.  This will ensure that the mapView is fully initialized AND in scope.
Ministeriodel_Interior
As the mentioned reference is added, I still can't find the solution
