arcpy.Parameter : how to create "The interactive feature input control"?
5941
5
11-15-2019 04:23 AM
RemigijusPankevičius
(ArcMap 10.5, but help pages I am referring are the same as in 10.7)
I am trying to make a GP tool within Python toolbox with kind of selection input: user selects features in ArcMap interactively.
I was reading
Using the interactive feature and record input controls—Help | ArcGIS Desktop
which show that it's possible for GP tool to have such kind of parameter. Quote: "The interactive feature input control gives you two methods for inputting features to a tool—either by clicking on a map display or by providing an existing dataset."
OK, so I check what parameter types I can create here:
Defining parameter data types in a Python toolbox—Help | ArcGIS Desktop
and it seems that Feature Set (GPFeatureRecordSetLayer)  is what I am looking for as description says: "Interactive features that draw the features when the tool is run.".
So here is my magic tool, but I do not see any way to "enter features interactively":
class AttachTool(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Add attachments"
        self.description = "Adds the same file as attachment to multiple selected features"
        self.canRunInBackground = False
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def getParameterInfo(self):
        """Define parameter definitions"""
        paramInputFeatures = arcpy.Parameter(
            displayName="Input Features",
            name="in_feature_set",
            datatype="GPFeatureRecordSetLayer", # Interactive features that draw the features when the tool is run
            parameterType="Required",
            direction="Input",
            multiValue = True)
        paramInputFile = arcpy.Parameter(
            displayName="File to attach",
            name="in_file",
            datatype="DEFile",
            direction="Input")
        return [paramInputFeatures, paramInputFile]
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        arcpy.AddMessage('Just pretending to do something...')
        return
Input field looks like this and I don't see how I should select features...
How the tool input looks like
MatthewDriscoll
MatthewDriscoll
Python
Do you suggest better to re-post in Python group?
MatthewDriscoll
No.   I was just getting more eyes on this for you by mentioning the group.
It seems that I misunderstood what "interactive input" means according to the help from Canada in the mentioned thread on gis.stackexchange.com.
So the question is a simple one now: Is it possible to create a GP tool with input that accepts selected features in ArcMap? (I will create a new question for this)
