Failed to add data: FeatureServer?
5746
11-11-2019 09:39 PM
by Anonymous User
Not applicable
I'm using ArcGIS Pro 2.4.1 and trying to add data from My Content on ArcGIS Online. I've never had issues with layers that I have added from ArcMap. All the layers that I have added using the Share -> Publish Web Layer, will not work with Pro. Anyone else having this issue?
Edit: I just tried adding a polygon layer with nothing but one polygon and got the error. I tried from ArcMap this time around. What is going on here?
Edit Again: I tried a different account and it worked so I uninstalled ArcGIS Pro, which might have been overkill, but I logged in and it worked again. Weird.
KoryKramer
Esri Esteemed Contributor
In Pro are you switching active portals?  Like maybe signing in with a Named User from one portal, which would then be the active portal, and then switching the active portal to another?
by Anonymous User
Not applicable
I do switch around quite a bit between accounts. It's working now that I signed out and back in.
KoryKramer
