I started with a raster dataset that I segmented, and from that segmented image, I generated training samples. I then classified the segmented image (using Random Tree) into 5 classes (leaves, grain heads, soil, shadows, and ground targets). The outputs generated from that process included a classified raster and a ECD file.
From there, I used the "Create Accuracy Points" to create the points needed to compute the confusion matrix. Parameters used:
I then tried to compute the confusion matrix, but all my results are zeros. I'm not sure why. Is there something that I have to do to merge my accuracy points with the classes of my classified raster
Hello, I know this is a long shot since this post is almost 3 years old, but do you remember if you ever solved this issue? I'm currently experiencing the same problem.
Thanks in advance!
Another long shot, but any chance you solved this issue and can remember how? Thank you!
