How to upgrade to 1.7.0
2392
11-04-2019 01:42 PM
Subu_Swaminathan_GISP
I have a previous ArcGIS Pro clone environment with ArcGIS API for python upgraded to 1.6.2. I would like to upgrade this now to 1.7.
conda upgrade -c esri arcgis - This does not work.
 If I try this? then i get the following
conda install arcgis=1.7.0
Fetching package metadata .............
Solving package specifications: .
UnsatisfiableError: The following specifications were found to be in conflict:
  - arcgis 1.6.*
  - arcgis 1.7.0*
Use "conda info <package>" to see the dependencies for each package.
Is it possible to use 1.7.0 version with ArcGIS Pro and update a package? Anyone else try this successfully?
DanPatterson_Retired
conda upgrade -c esri arcgis --no-pin --dry-run
check to see what would happen during a "dry-run" first and if everything seems ok, then drop the --dry-run part
Thanks Dan.
That works.
The following packages will be UPDATED:
    arcgis: 1.6.2-py36h4f45381_633 esri --> 1.7.0-py36_863 esri
then proceeds to completion.
DavidWasserman
Hi Dan,
Does this version of ArcGIS Python API fix issues with spatial.to_featureclass?
David
David Wasserman, AICP
