Create Folder and File in QT Creator
8334
10-25-2019 08:09 AM
jaykapalczynski
Honored Contributor
For the longest time I have been able to simply create a folder in Explorer and copy and paste file sin there and they would how up in QT Creator.
I now go into File Explorer and create a folder and nothing appears in QT Creator......I can see them in FE
The only way I was able to create a folder was right-click on the 'MyApp' root folder in QtCreator, select 'Add New' and choose to add a new QML file. At that point, it brings up a file Browse dialog and you can navigate to the folder you created and drop the file in there.  I then deleted the file.
BUT I cannot copy and paste a file in there....
what gives....any ideas?
ErwinSoekianto
Esri Alum
Go to <your-project-name>.qmlproject file and add the .sql extension in the Files filter
jaykapalczynski
Honored Contributor
Qt Creator Version 4.9.2
ErwinSoekianto
Esri Alum
Jay,
I just test this in Qt Creator 4.9.2 that is bundled with AppStudio 4.0.93
I was able to go into the File Explorer of the app from Qt Creator by right-clicking on any folder or files in the project, then I created a folder in the File Explorer,  but this folder would not show in Qt Creator if it is still empty. The folder would then show up in Qt Creator after I copy-pasted at least one file in the folder. I was able to do this with image file, qml file and json file.
What file(s) are you trying to add in the new folder?
Thank you,
Erwin
jaykapalczynski
Honored Contributor
OK I created a folder and copied an existing .qml file in there and it appeared...
I was trying to put in a .sql file in there from an ESRI example and the file does NOT show up.  How do I get that .sql file to show up.
ErwinSoekianto
Esri Alum
