Create Point Graphic from Input boxes values
1530
10-17-2019 09:18 PM
victhomas
Hello all,
I'm having trouble creating point graphic on a map from input values box.  Below are the code that I have.  I'm trying to get the lat and long values that is entered to plot on the map after the button is clicked.  Any help on how to get the global input values into the require() to generate the point graphic would be appreciated.  Thanks,
<html>
<head>
	<meta charset="utf-8">
	<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
	<title>Create Point Graphic</title>
	<style>
		 #viewDiv {
			padding: 0;
			margin: 0;
			height: 600px;
			width: 100%;
		  #getInput{
			margin-left: 100px;
			height: 100px;
	</style>
	<link rel="stylesheet" href="https://js.arcgis.com/4.12/esri/css/main.css">
	<script src="https://js.arcgis.com/4.12/"></script>
	<script>
		var longi = -96.867;
		var lati = 40.228;
		var lontest;
		var lattest;
		function plotPoint()
			lontest = document.getElementById("longInput").value;
			lattest = document.getElementById("latInput").value;
			alert("Long: "+lontest +" Lat: "+lattest);
		require([
		  "esri/Map",
		  "esri/views/MapView",
		  "esri/Graphic",
		  "esri/layers/GraphicsLayer"
		], function(Map, MapView, Graphic, GraphicsLayer)
			var map = new Map({
				basemap: "topo-vector"
			var view = new MapView({
				container: "viewDiv",
				map: map,
				center: [-96.8670, 40.228],
				zoom: 6
			var graphicsLayer = new GraphicsLayer();
			map.add(graphicsLayer);
			// Create a point
			var point = {
				type: "point",
				longitude: lontest ,
				latitude: lattest
			var simpleMarkerSymbol = {
				type: "simple-marker",
				color: [226, 119, 40],  // orange
				outline: {
					 color: [12, 137, 148],
					 width: 1
			var pointGraphic = new Graphic({
				geometry: point,
				symbol: simpleMarkerSymbol
			graphicsLayer.add(pointGraphic);
	</script>
</head>
<body>
	<div id="getInput">
		Latitude:<br>
		<input id="latInput" type="text" name="latpoint">
		<br>
		Longitude:<br>
		<input id="longInput" type="text" name="longpoint">
		<button onclick="plotPoint()"> Click Me</button>
	</div>
  <div id="viewDiv"></div>
</body>
</html>
RobertScheitlin__GISP
Vic,
  Here is your code working:
<html>
<head>
  <style>
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #getInput {
      margin-left: 100px;
      position: relative;
      padding: 12px 15px;
  </style>
  <script>
    var lati = 40.228;
    var lontest;
    var lattest;
    var plotPoint;
    require([
      "esri/Map",
      "esri/Graphic",
    ], function (Map, MapView, Graphic, GraphicsLayer) {
      var map = new Map({
        map: map,
        zoom: 6
      plotPoint = function() {
        // Create a point
        var point = {
          type: "point",
          longitude: lontest,
          latitude: lattest
          outline: {
            width: 1
          geometry: point,
      view.ui.add(getInput, "top-right");
  </script>
</head>
<body>
  <div id="getInput" class='esri-widget esri-widget--panel'>
    Latitude:<br>
    <input id="latInput" type="text" name="latpoint" value='40.228'>
    <br>
    Longitude:<br>
    <input id="longInput" type="text" name="longpoint" value='-96.867'>
  </div>
</body>
</html>
Vic,
<html>
<head>
  <style>
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #getInput {
      margin-left: 100px;
      position: relative;
      padding: 12px 15px;
  </style>
  <script>
    var lati = 40.228;
    var lontest;
    var lattest;
    var plotPoint;
    require([
      "esri/Map",
      "esri/Graphic",
      var map = new Map({
        map: map,
        zoom: 6
        // Create a point
        var point = {
          type: "point",
          longitude: lontest,
          latitude: lattest
          outline: {
            width: 1
          geometry: point,
  </script>
</head>
<body>
    Latitude:<br>
    <br>
    Longitude:<br>
  </div>
</body>
</html>
