Why won't a custom Toolset added to Arcmap execute?
659
10-17-2019 07:15 AM
MatthewElbert1
Robert Scheitlin, GISP
So I've recently been attempting to calculate road widths for a project, and I figured there must be some toolset to do large areas fairly quickly.  I've come across a custom toolset for calculating road/stream widths (link to tool below).  Yet the toolset won't actually execute once I've added it to ArcMap.
A few pieces of info:
1. I'm using ArcMap v.10.5.1
2. I have a road widths .shp, as well as road centerline (both necessary for executing the toolset)
3. Upon initial test, I received this: 'ERROR 000824: The tool is not licensed.' (perhaps I haven't properly added/activated the custom toolset?)
4.  I'm going to trying to create a geodatabase in which all of my input/output datasets are stored to see if that fixes the issue.
5.  If I can't find a solution, is there an easier way to do this in either ArcMap or ArcPro?
Toolset Link:
https://www.arcgis.com/home/item.html?id=ede4729410e846638520f99901542518
I'll try a couple more things with this toolset and I appreciate any/all feedback I can get on this.
-Matt
RobertScheitlin__GISP
Matt,
   There are many reasons one of the most popular is the the GPs use of scratch workspace that is not normally available to a GP that is published over the web. In the ArcGIS help docs there is info about making a GP tool online compatiable. I don't have the link right now it has been a long time since I have played with GPs.
