CAD layers missing in feature class.
1318
10-16-2019 01:34 PM
VaL
Hi
I have a CAD dwg with 103 layers in it. Using arcmap 10.7.1.
When I import as feature classes (in geodatabase) I get 4 FC for the 4 geometries. There is a attribute field of layer in each of them, listing the CAD layers as attributes.
However the number of unique layer values across all 4 FC is 67 instead of 103.
What might be the problem and where are the remaining layers?
AdrianWelsh
MVP Honored Contributor
Vasil Lefterov,
This is kind of an age old question. For me, when I see CAD issues like this, I try all sorts of trouble shooting to make it work.
Have you tried just adding your CAD file as a layer instead of importing into the GDB?
Is there a similarity in what you're not seeing?
Is there something special about these missing layers (like are they 3D or have custom values/symbologies)?
Have you tried messing with the CAD drawing itself to see if it will import correctly (like converting it to a different CAD file type or exporting out a separate copy)?
Have you zoomed to the full extent to see if the layers/features ended up somewhere else? Are they showing up in the attribute table?
Those are a few suggestions to start with.
