Problems to deploy Water Distribution Network Editor v3.2
2287
10-10-2019 08:23 AM
NorahGallucci
When I try to deploy Water Distribution Network Editor v3.2 I get a fail, It says that Layer's data source is inaccessible, but I don't know where find the disruption.
I already deploy Water Distribution Network Viewer v3.2 and It works perfectly with the same published Utility Network demo data.
SolutionsWater Utilities
JoelSmith3
Esri Alum
Hi Norah,
It appears that you have a previous version of the Water Distribution Utility Network Foundation deployed (possibly version 3.0). Notice the blue exclamation next, this indicates a newer version is available.
The rectifier cable was added at version 3.2
I would recommend deploying the new Water Distribution Utility Network Foundation, publishing a new service, and then deploying the Editor and Viewer.
Joel
JoelSmith3
Esri Alum
Hi Norah,
Joel
NorahGallucci
Hi Joel!
Thank you very much for your answer. I did what you suggest, but when I try to deploy the Editor Pro ask for Portal credential for arcgisutilitysolutions.esri.com (I attach an image about this issue).
Do you know what I should do?
GelisaSlyer
Norah,
Sorry for the inconvenience, we had to make an update on our end but you should be good to deploy the Water Distribution Network Editor now.
Gelisa
NorahGallucci
Hi Gelisa!
Thank you very much for your answer, I just deploy the Editor and It works.
I´m really happy about that
