Unable to read Sqlite non-spatial with Data Interoperability
2061
10-04-2019 11:30 PM
SeanGrant1
How come the Sqlite non-spatial reader in Data Interop requires a database connection that doesn't let you specify sqllite non-spatial? If you choose the only sqlite option (spatial) , the connection remains red and doesnt let you read data.
Steps to repro
  1. Add a new reader
  2. Choose sqlite non-spatial
  3. Select a database
  4. Click Parameters (since you have to because it is red)
  5. In the database dropdown, choose the only Sqlite option (Sqlite Spatial)
  6. Give it a name and specify database
If you test it will say it isn't licensed. I do not see any way sqlite  non spatial db can be read
ArcGIS Pro 2.4.1
BruceHarold
Esri Frequent Contributor
Hello All
We found the issue, you can fix it for Pro by renaming this file (don't delete it, see below):
C:\Program Files\ArcGIS\Data Interoperability for ArcGIS Pro\formatsinfo\sqlite3.db
This action will need to be undone when installing Pro 2.5.
The issue will still be found in ArcMap/Catalog until ArcGIS 10.8.
AdrianWelsh
MVP Honored Contributor
Tagging Bruce Harold‌ on this.
BruceHarold
Hi Sean
This looks like a UI bug.
I can copy-paste a reader into a workspace so I'll share that with you, but I'm on Pro 2.5 so the FME Engine will be 2019.1.2, if this causes the SQLITE3 reader to not arrive let me know.
BruceHarold
Hello All
