Multiple maps and widgets
1286
10-03-2019 09:55 PM
JessNewton1
If you have multiple maps, is it possible to have different widgets appear when a map is selected and to "dissappear" when another map is selected that doesn't use that widget??
DerekLaw
Esri Esteemed Contributor
Hi Jess,
This functionality is not possible with Ops Dashboard. May I suggest the following: why don't you setup a map element with its respective elements in one Dashboard layout, then setup the second map element with its respective elements - and stack this on top of the first layout? or you could have 2 separate Dashboards and "contain" them together in a single app, in a StoryMap.
Hope this helps,
