ArcGIS Javascript API v3.29 - Mobile infoWindow fullscreen on touch
1183
09-20-2019 12:46 PM
MaximeDemers
I would like to know if it's possible to show the infoWindow directly fullscreen after a touch event on mobile instead of showing a small popup in which you have to click again to display the info fullscreen.
I would like to prevent this popup above and automatically show the fullscreen InfoWindow like below.
It's for a 2D WAB application in version 2.13 so the ArcGIS Javascript API version is 3.29.
Any suggestion?
Thank you!
CarlosNantes
A quick and dirty way of doing it, could be something like this:
function configurePopupMobileToMaximize (map) {
    require(['dojo/aspect'], function(aspect){
            aspect.after(map.infoWindow'onSelectionChange'function () {
                var feature = map.infoWindow.getSelectedFeature();
                if (feature !== undefined && map.infoWindow._toggleView) {
                    map.infoWindow._toggleView();
Then just call somewhere this function to configure the behaviour before the user open some popup.
configurePopupMobileToMaximize(myMap);
Now, this uses a "private" function _toogleView() that we probably shouldn't use directly for some reason. Also, you probably should require the aspect module somewhere else (like a define block) and not inside the function.
But it works.
CarlosNantes
But it works.
MaximeDemers
Nice and simple! Thank you Carlos for sharing this,
