Survey123 with Repeat backed up in Pro
343
09-18-2019 08:09 AM
ReneAubut
Hi, I have a Survey123 form using a repeat working great. When this dataset is loaded in ArcGIS Pro, I see the feature class and the standalone table being added. I want to perform a backup using FC to FC but only the feature is backed, not the related table. I know I could use the Export Data function in AGOL where i am getting both, the feature class and the related table linked by a GDB relationship class. but my workflow is more efficient if i can do all from Pro.
Tags (1)
KoryKramer
Esri Community Moderator
ReneAubut
Thanks Kory. Not sure how to copy my source data, hosted on ArcGIS Online and pasting it on our server. In Pro, making a right click on the AGOL data will popup "Add to Current Map" - "Add to New Map" or "Delete"
KoryKramer
OH, sorry, guess I didn't quite understand the whole workflow.  Like you stated in the original post, I think you'd have to download the data from ArcGIS Online for the backup.
ReneAubut
Thanks Kory
