Hi, I have a Survey123 form using a repeat working great. When this dataset is loaded in ArcGIS Pro, I see the feature class and the standalone table being added. I want to perform a backup using FC to FC but only the feature is backed, not the related table. I know I could use the Export Data function in AGOL where i am getting both, the feature class and the related table linked by a GDB relationship class. but my workflow is more efficient if i can do all from Pro.
Have you just tried Copy/Paste? Copy feature datasets, feature classes, and tables to a geodatabase—Geodatabases | ArcGIS Desktop
Thanks Kory. Not sure how to copy my source data, hosted on ArcGIS Online and pasting it on our server. In Pro, making a right click on the AGOL data will popup "Add to Current Map" - "Add to New Map" or "Delete"
OH, sorry, guess I didn't quite understand the whole workflow. Like you stated in the original post, I think you'd have to download the data from ArcGIS Online for the backup.
Thanks Kory
