Javascript 4 & Geoprocessing Service with File Upload
1847
09-17-2019 05:40 AM
mdonnelly
I have created a geoprocessing service, with upload enabled, that takes a file as a parameter. I am attempting to call this service from a web application created using Javascript 4.12, however, I have a problem.
The first problem happens when I use the esri request module to transact with the service's upload endpoint. The response will always be returned as html rather than JSON. If I nominate the responseType as "json" I get an error saying there was an unexpected character '<'. If I nominate the responseType as "text" the request succeeds but the response is in html.
        var gpUrl =  "https://myserver.com/arcgis/rest/services/ImportFileToGDB/GPServer/ImportFileToGDB";
        var fileUploadUrl =  "https://myserver.com/arcgis/rest/services/ImportFileToGDB/GPServer/uploads/upload";
        document
          .getElementById("uploadForm")
          .addEventListener("change", function(event) {
            var fileName = event.target.value.toLowerCase();
            if (fileName.indexOf(".zip") !== -1) {
              //is file a zip - if not notify user
              uploadFile(fileName);
            } else {
              document.getElementById("upload-status").innerHTML =
                'Add shapefile as .zip file';
        var gp = new Geoprocessor(gpUrl);
        var fileForm = document.getElementById("mainWindow");
        var expand = new Expand({
          expandIconClass: "esri-icon-upload",
          view: view,
          content: fileForm
        view.ui.add(expand, "top-right");
        function uploadFile(fileName) {
            //upload the zip file and get back the itemID (via uploadSucceeded)
            var upload = esriRequest(
                fileUploadUrl,
                    body: document.getElementById("uploadForm"),
                    method: "post",
                    responseType: "json"/*,
                    query:{f:"json"},
                    headers: {"Content-Type": "application/json"}*/
            ).then(uploadSucceeded, errBack);
        function uploadSucceeded(result) {
          document.getElementById("upload-status").innerHTML = "File uploaded"
          var itemID = result.item.itemId;
          //Create the DataFile object you will assign your itemID to
          var dataFile = new DataFile();
          //The itemID points to the zip file, which is why I assign it the dataFile object
          dataFile.itemID = itemID;
          var params = {
             "Import_File": dataFile
          gp.submitJob(params).then(handleResult, errBack, progTest);
        function progTest(value) {
          document.getElementById("upload-status").innerHTML = "Job status: " + "'" + value.jobStatus + "'";
          console.log(value.jobStatus);
        function handleResult(result) {
            //Handle the querying, zooming and opening the FeatureForm
            document.getElementById("upload-status").innerHTML = "Success";
            console.log('here');
        function errBack(error) {
          document.getElementById("upload-status").innerHTML = "Error: " + error;
          console.log("gp error: ", error);
Regards,
Mark
mdonnelly
Closing the loop on this one with a blog post I wrote here:
https://community.esri.com/people/MDonnellyesriaustralia-com-au-esridist/blog/2019/10/17/js-api-v4-u...
Regards,
Mark
