R Shiny app from ArcGIS
5876
5
09-12-2019 04:20 AM
DavidMatthews3
I have a toolbox containing an R script that creates a shiny app. When I run the script the app begins to render in a browser but then goes grey and I get an error saying 'c stack close to limit'
 The script works fine in rstudio and is based on this bridging-R-ArcGIS/interactiveKriging.R at master · BenGraeler/bridging-R-ArcGIS · GitHub
Any ideas?
by Anonymous User
Not applicable
It seems enough system memory is not allocated when app is called from the browser. RStudio has its own defaults for the memory limit which can be higher than the one allocated when the app is run in an another system. You can see how much memory R-Studio allocated with
memory.limit()
You can update the amount of memory your operating system allocated by setting the parameter
setrlimit(2)
Here is more information about setting this limit.
DavidMatthews3
Thanks,Orhun
I'm on windows computer so setrlimit is not an option.
Do you have any other ideas?
Cheers
ShaunWalbridge
How much memory is installed on the machine you're using for this analysis? Does it work with smaller inputs? Setting the stack size on Windows requires editing the executable file (its a compile-time option), which requires Visual Studio. Do you know where it gets in the execution prior to the stack size limit being hit?
Shaun
DavidMatthews3
Thanks for your help guys.
I've been doing some testing and seems to rendering the graph that is the problem. If I comment out line 40 ie. no graph displayed it works fine. But the script. including graph works in r studio (without tool_exec <- function...)
Here is the code I've been testing. Which the ArcGIS Toolbox script points to
### Interactive R and Arcgis Example
tool_exec <- function(in_params, out_params){
 arc.progress_label("Loading packages ...")
 arc.progress_pos(10)
 library(shiny)
 library(dplyr)
 ### Load Data
 arc.progress_label("Loading data ...")
 arc.progress_pos(20)
 Year<-c(2000,2001,2002,2003,2000,2003,2000,2000,2005)
 Dwells<-c(50,20,25,26,27,300,100,80,100)
 df_test <- data.frame(Year,Dwells)
 ### Load App
 arc.progress_label("Starting App ...")
 arc.progress_pos(50)
 ui <- fluidPage(
 sidebarLayout(
 sidebarPanel(sliderInput("Explore_Years", 'Select years to explore',
 min=2000, max= 2005,value = c(2000,2005),sep='')),
 mainPanel(textOutput("text_out")
 , tableOutput("table_out")
 , plotOutput("graph_out") #####<<<< Works if comment this line out#######
 server <- function(input, output) {
 Summary_test<-reactive({
 df_test%>%
 filter((Year >= input$Explore_Years[1]),
 (Year <= input$Explore_Years[2]) ) %>%
 group_by(Year)%>%
 summarize(Dwellings = sum(Dwells))
 output$text_out <- renderText({paste ("You have selected minimum year ",input$Explore_Years[1])
 output$table_out <- renderTable({Summary_test()
 output$graph_out <- renderPlot({
 plot(Summary_test()$Year,Summary_test()$Dwellings)
 runApp(list(ui = ui, server = server))
MarcoGalfetti
same errors with plotOutput and renderPlot... some solutions so far?
same app with textOutput and renderText work correctly
