How to add a OGC WMS layer to application using Javascript API 4.12
3716
09-11-2019 11:52 PM
PieterHoltzhausen1
I am trying to load the WMS layers into my JavaScript application, but I get a "failed to fetch” error message.
Her is my js code to just display the resource in an empty map:
      require([
        "esri/Map",
        "esri/views/MapView",
        "esri/layers/WMSLayer"
      ], function(Map, MapView, WMSLayer) {
        var layer = new WMSLayer({
          url:
            "http://apollo.cdngiportal.co.za/erdas-iws/ogc/wms/CDNGI_PORTAL_BACKDROP?",
          sublayers: [
        var map = new Map({
          layers: [layer]
        var view = new MapView({
          container: "viewDiv",
          map: map,
          spatialReference: 4326,
Any guidance would be much appreciated,
Pieter
FC_Basson
The API is forcing the request to the WMS service to be HTTPS, but the NGI server is not providing SSL connections yet.  You must redirect the request through a proxy as described in the Proxy pages with the API | ArcGIS API for JavaScript 4.13
For the NGI server you can add this to your code:
urlUtils.addProxyRule({
    urlPrefix: "http://apollo.cdngiportal.co.za/erdas-iws/ogc/wmts",
    proxyUrl: "https://<server>/proxy"
So you'll need to setup the proxy page (if you don't have one yet, which you can configure).  Use the GitHub examples: GitHub - Esri/resource-proxy: Proxy files for DotNet, Java and PHP.
DavidTshamussa
i'm facing same issue. any response from the community please.
FC_Basson
