Drop Down Field in Survey 123
527
09-11-2019 08:42 AM
KrissyLukens
Are there any "auto" fields for #Survey123 that can be used?
For example . . . I'm looking for a drop-down field that asks users to select a State from the US. I'd rather not type in all of the states. Does this already exist that I could use?#
JamesTedrick
Esri Esteemed Contributor
Hi Krissy,
There aren't preset lists for U.S. States (or other secondary or tertiary administrative areas) available via either the Survey123 web designer or Survey123 Connect.  I would suggest exporting a table from a feature layer so that you could copy/paste the values (and appropriate code values, whether that would be a postal abbreviation or FIPS code).
