Calculate Field with Python 3 / <Null> values
7102
5
09-04-2019 01:01 PM
JustinWolff
I'm attempting to concatenate several fields, where one of the source fields is a double, the rest are string, and all of them have some <Null> values.  If I use the following syntax in Calculate Field in Pro 24.1/Python 3:
str(!AddrPrimaryHighNo!) + " " + str(!StreetPreDrctnAbbrev!) + " " + str(!StreetName!) + " " + str(!StreetSuffixAbbrev!) + " " + str(!StreetPostDrctnAbbrev!)
I get values like:
1498.0 None AVENUE K NONE NONE
where I would expect:
1498  AVENUE K
AddrPrimaryHighNo is Double
StreetPreDrctnAbbrev is Text
StreetName is Text
StreetSuffixAbbrev is Text
StreetostDrctnAbbrev is Text
If I perform the field calculation below in ArcMap 10.5.1/VB Script, it works out just fine:
[AddrPrimaryHighNo]&" "& [StreetPreDrctnAbbrev]&" "& [StreetName]&" "& [StreetSuffixAbbrev]&" "& [StreetPostDrctnAbbrev]
Meanwhile I'm just going to go back to ArcMap.  Thanks
-Justin
LanceCole
https://community.esri.com/migrated-users/3420 ,
You are correct, I should not assume Justin would understand how to place a def in a code block.  I was also using my phone to reply while traveling.  Below are the call, def and a Calculate Field screen shot to use a function called "joinAddress" with the needed address fields which returns the assembled address string less any None values.
You call the function using:
joinAddress(!AddrPrimaryHighNo!, !StreetPreDrctnAbbrev!, !StreetName!, !StreetSuffixAbbrev!, !StreetPostDrctnAbbrev!)
The Code Block:
def joinAddress(a,b,c,d,e):
    flds = [a,b,c,d,e]
    return " ".join([str(i) for i in flds if i is not None])‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Side note: If all your fields were string you could also use " ".join(filter(None, flds)).  You can still use this by changing the following; flds = [str(a),b,c,d,e].  I prefer the method above as you can also change the str(i) to str(i).strip() to remove any leading or training spaces that may be in your fields.
Calculate Field:
Calculate Field
If you do not want to use the code block with a call, you can use the following as a calculate statement:
" ".join([str(i) for i in [!AddrPrimaryHighNo!, !StreetPreDrctnAbbrev!, !StreetName!, !StreetSuffixAbbrev!, !streetPostDrctnAbbrev!] if i is not None])
LanceCole
Justin,
You can use something like the following as a def in a code block:
flds = [!AddrPrimaryHighNo!, !StreetPreDrctnAbbrev!, !StreetName!, !StreetSuffixAbbrev!, !StreetPostDrctnAbbrev!]
" ".join([str(i) for i in flds if i is not None])‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoshuaBixby
MVP Esteemed Contributor
Although I agree with this approach, it won't work within the Field Calculator unless the user creates a code block.  Creating a function in a code block and passing the fields to it isn't difficult, I am just not sure whether that is more than the OP wants to deal with.
LanceCole
The Code Block:
    flds = [a,b,c,d,e]
Calculate Field:
Calculate Field
JoshuaBixby
Are you really getting values like:
or is it
1498.0 None AVENUE K None None
JustinWolff
Josh,
I've since modified my data so the AddrPrimaryHighNo field is now a string, but for the following (when AddrPrimaryHighNo was a double):
AddrPrimaryHighNoStreetPreDrctnAbbrevStreetNameStreetSuffixAbbrevStreetPostDrctnAbbrev
1699<Null>220THST<Null>
When I use:
I receive:
1699.0 None 220TH ST None
So I may have not typed out the correct outcome in my original message, sorry about that.
Thank you all for your quick replies and helpful information.  A coworker also pointed out there is a Concatenate Fields under Helpers in the Calculate Field geoprocessing window, which sets up a code block with a def, etc.
-Justin
