Function PULL DATA in a date question
1199
09-02-2019 09:38 AM
CUARTA_OPORTUNIDADLOCAL
I have mi attachment in .csv, in this there are dates that i need in my survey, through the pulldata function I want to fill out several date questions, but in these questions the pulldata doesn't work, I need help on that
by Anonymous User
Not applicable
Hi Liliana,
Have you tried using pulldata on a note or text field so you can see the data being retrieved from the CSV and how it is formatted in the form in that note or text field. If the format is not correct, you will need to use format-date to get it into a format that can be applied to the date question.
Phil.
